Re: Timing a Farmall A
Posted by El Toro on January 02, 2011 at 07:18:12 from (108.3.200.96):
In Reply to: Timing a Farmall A posted by Dahlin on January 01, 2011 at 13:53:34:
When No1 piston is at TDC on the compression stroke both valves on No1 piston should be closed. Then rotate the rotor to the No1 plug tower which is about 1 o'clock and then install your mag. Hal
PS: Once you feel that compression against your thumb drop a long plastic straw on top of the piston and you watch the straw rise as a helper hand cranks the engine slowly.
