Posted by Tom Fleming on January 02, 2011 at 13:46:53 from (67.20.243.240):
In Reply to: Ho of F-30 M posted by Farmallb on January 01, 2011 at 09:57:27:
F-30 is 24.9 at the drawbar and 32.8 at the belt. 5,300 lbs. without added weight. bore and stroke 4.25x5.00 inches 283.7 CID 1200 RPMs
M is 33.1 at the drawbar and 36.6 at the belt 4,900 lbs. without added weight. bore and stroke 3.875x5.25 inches 247.7 CID 1450 RPMs
so 9 more HP at the drawbar, but 400 lbs lighter. The F-30 is probably geared lower. I would expect the torque on the F-30 to equal or better the M at the same RPM. The f-30 should lug better, but the M with 9 more HP should be able to pull an extra plow.
so, using the farmall Cub as the base (at 9 HP and a 1 12" plow tractor), the M should pull 1 more plow than the F-30. My conclusion, it is VERY close to a toss-up, but I give the M the edge. They are so close, not sure I want to put money either way.
all my comments are based upon each tractor being STOCK, and not modified. I am a big fan of torque, but you do need the ponies to get work done.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
