No. Remove the driveshaft by loosening the 2socket head set screws on transmission U joint. Remove driveshaft and throwout bearing. Use a 3/4 inch wrench to remove tension from the idlers on PTO drive belts and remove belts. Re move three capscrews from the 2 groove pulley that drives the PTO. You may have to turn the engine just so so for the drive sheave to come out. Remove the capscrews in the clutch pressure plate. Remove the bolts that fasten the flywheel to the crankshaft. Its not a real difficult job but small hands and patience help. If you need torque specs for the flywheel capscrews I can look them up for you, my shopmanual is at the shop and not handy now. Joe
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
