Re: 300U Manual Steering Arms
Posted by Janicholson on January 03, 2011 at 05:47:29 from (67.72.98.45):
In Reply to: Re: 300U Manual Steering Arms posted by Dellbertt on January 03, 2011 at 05:06:45:
Longer arms on the spindles only, not on the box,(lets say 2 inches) will for sure make it steer easier. It will also not change the angle of the dangle in respect to the ground.
It might not steer all the way to the spindle stops, due to increased travel. Thus there may be reduced turning radius. It also might allow the steering box to continuously run up against its internal limits. (I do not know if this is bad, but those mechanical boxes are fragile.) Jim
