Hi, has the water pump shaft and bearing been replaced? It is very difficult to tell where the leak is coming from as you said as the fan blows the coolant back against the engine block. If it is the water pump eventually it will leak when the engine is off. There is a coolant channel behind the water pump that has a gasket. Go to caseih.com then search for parts then enter D-239 and you will see parts breakdown.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
