Re: Farmall 300 Hydraulic System Problem
Posted by Wardner on January 03, 2011 at 19:54:47 from (4.154.255.163):
In Reply to: Re: Farmall 300 Hydraulic System Problem posted by Wardner on January 03, 2011 at 19:44:05:
Forgot to mention that the right O-rings will fix the problem. The pump is just sucking air at the moment. If it doesn't work, pull the manifold away from the casting and fill both tubes with hydraulic oil using a pump oiler. Might help if the front end of tractor is considerably lower than the rear.
