Re: Rebuild of Steering on Super A
Posted by gene bender on January 04, 2011 at 07:26:05 from (67.55.227.196):
In Reply to: Rebuild of Steering on Super A posted by Mark W. on January 04, 2011 at 05:54:13:
If there isnt and end play when you turn the wheels the bearing is good. Now the procedure is replacing the nut a sealent should be used to keep the threads from leaking. Teflon tape should work. Iv had good results after rebuilding. I have done several bushings seals and the bearings. Woodruff key on the gear sometimes is worn but if thats all the problems you have the tape should do it.
