Re: Farmall C or Super A Hydraulic Pump Rebuild
Posted by gene bender on January 04, 2011 at 13:56:08 from (67.55.227.196):
In Reply to: Re: Farmall C or Super A Hydraulic Pump Rebuild posted by ihtrucker on January 04, 2011 at 11:46:28:
Correct you mite want to clean the filter in the rockshaft area when the fluid id drained as you loosen the pipes going to the pump there will be some fluid run out. You will then need to remove the other end at the rockshaft so you can remove the pump. There will be more drainage when you remove tehpipes from the rockshaft. When installing before you put the pipe assy back fill the pump with oil helps to prime them when starting usually no problems. Some pumps do have a set screw in the pump that can also be used for priming. After its all back together start engine and move the levers back and forth to remove any air in the system.
