Re: Priming the Cub oil pump
Posted by Janicholson on January 04, 2011 at 18:13:25 from (67.72.98.45):
In Reply to: Re: Priming the Cub oil pump posted by Dave H (MI) on January 04, 2011 at 17:31:08:
Your concept is correct. If every oil passage is filled, including the pickup tube to the pump, it will have pressure immediately when started. Many people pack the pump (especially on a Cub engine) with Vaseline to assure solid vacuum to the pickup strainer.
When the air is all shoved out of the small passages. the resistance on the pump will go up (you will feel resistance when pumping) Jim
