Re: Farmall A AV Transmission Question
Posted by Lmack on January 04, 2011 at 18:56:02 from (98.66.240.32):
In Reply to: Farmall A AV Transmission Question posted by simpsonc9 on January 04, 2011 at 18:22:35:
I would make my decision based on how much you have to spend, how much you plan to use the tractor, and how willing you are to clean it up. If this is not going to be a work tractor, the gears will get very little use in the future. Clean them up, clean the transmission, put in new oil and use the old gears unless money is not a factor. However if you plan to actually work the tractor on a regular basis replace the gears. Many of the old tractors that have been sitting for a while will look like that or worse before they are moved or run. The wear show is from trying to mesh the gears with the transmission spinning (gear grinding). All the old tractors will have gears that look like that.
