Rust forms in a "cellular" sort of way. After cleaning, you may find that enough of the original contact surface area remains so that the gear is serviceable for light use.
I would clean the rust with a small needle scaler at low pressure. Pack the area with oily rags or paper to retain the rust. Pick up the crud with a magnet. If no scaler, use steel wool. Meanwhile I would create an eBay alert on those gears and the ones below. Buy a cheap set and put them on the shelf in case you need them later. I think a high quality epoxy filler might work to fill pits.
Oil level is determined by the check oil level plug on the side of the casting.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
