Re: 12V positive or 12V negative?
Posted by rvirgil_KS on January 05, 2011 at 13:15:13 from (205.162.222.176):
In Reply to: Re: 12V positive or 12V negative? posted by Theman on January 05, 2011 at 10:36:53:
The points are the grounding switch in both postive and negative ground. With both polarities the wiring goes from battery "hot post" to ignition switch, to coil, to distributor where the points are located.
If using a 6 volt coil with 12 volt system a resister is installed between switch and coil to limit current.
With negative ground the negative post on coil goes to distributor. With positive ground the positive post on coil goes to ground.
Trouble shooting procedures would be the same for either polarity.
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
