Re: Re: Super MTA diesel parts
Posted by the tractor vet on July 07, 2000 at 18:50:05 from (216.196.12.89):
In Reply to: Re: Super MTA diesel parts posted by Dick Bowman on July 04, 2000 at 15:32:19:
you can get your sleve assy. and your gskt. and rod bearings from case ih .but you will have to hunt for main bearings there are only a few sets left theresome std . no .010 there are .020 and.030 that is all that i know of i am in the procese in restoring one for acustermer at this time the problem i am haqving is that the crank shaft thrust on the past 5 cranks are to far gone thay do not make oversize thrusts so make sure on your sizes when you do it
Post A Followup
: Re: Re: Re: Super MTA diesel parts
