Posted by gene bender on January 06, 2011 at 01:45:27 from (67.55.227.196):
In Reply to: 6 volt battery posted by Stones Throw Farmer on January 05, 2011 at 17:21:08:
You need to remove the caps when charging the battery as it sounds like you have overcharged and need to clean it with baking soda as the batt box is probably starting to get eaten out from the discharge. You dont need to keep a charger on if you arent using the tractor if the charging system doesent work get it fixed probably need new brushes and bearings in the gen. Better check the fluid level as its probably low from overcharging. Get a hydrometer and check the cells for SP this will tell you if the battery needs chatging.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
