Re: Hydraulic problems for an H
Posted by mkirsch on January 06, 2011 at 05:55:01 from (64.80.108.56):
In Reply to: Hydraulic problems for an H posted by Fuller's Farmalls on January 05, 2011 at 16:56:51:
6 quarts is often not enough to raise these loaders all the way, so they have auxiliary reservoirs.
If the loader uses the tops of the cylinders for auxiliary reservoirs, the cap should NOT be vented.
Problem is, you don't know what you're looking at and we can't see what you're looking at, so there's no way we can be 100% sure of what you have.
There should be hoses running from the fill pipe on your belly pump, up to the tops of the hydraulic cylinders, if they are being used for auxiliary reservoirs.
If there are no hoses running from the fill pipe on your belly pump, then it does not have an auxiliary reservoir. 6 quarts would be all you need in this case.
