Re: 300 Voltage Regulator Wiring
Posted by twopop on July 07, 2000 at 20:22:51 from (208.224.38.172):
In Reply to: 300 Voltage Regulator Wiring posted by Ray MI on July 07, 2000 at 19:40:35:
on the regulator where the wires hook up,on the little tabs there should be the following marks.ARM BAT FLD the bat term should be hot at all times, the wire comes from the amp guage. the arm wire runs from the reg. to the arm term. on generator the fld wire runs from the reg. to the fld term. on the generator.Insure that the + term. of the battery is grounded with engine running temperarily touch the bat and arm term. together with a short piece of wire,to polarize the reg.to make sure about the battery ground the reg should be stamped POS GRD
Post A Followup
: Re: Re: 300 Voltage Regulator Wiring
Today's Featured Article - Product Review: Kreem Brand Fuel Tank Liner - by Staff. This condition has occurred on a few machines that we have had and fortunately we were able to borrow the technique used at the local motorcycle shop. The product that we have used is called Kreem thouh there are others on the market, this one was recommended and available. This particular product is sold in three parts, a bottle of etch, dryer, and sealer. We were fortunate enough to start the process with stern warnings from those that had used this type of product before. The horror ... [Read Article]
