Posted by Janicholson on January 06, 2011 at 07:18:29 from (199.17.6.126):
In Reply to: Re: 6 volt battery posted by Stones Throw Farmer on January 06, 2011 at 06:44:59:
If the battery ids charged, it will be at 6.3 volts (or very close) when it is not being charged, and everything is turned off or it is disconnected. If the charger is then hooked up, and it has a maintenance function, it should read about 1/2 volt higher than the voltage noted above. If it is more like a volt and a half, it is not in maintenance mode. New batteries can be bad. Do not over fill the cells. Do not fail to nutralize and clean off the acid now spilled. Use a hydrometer to check cell specific gravity. Charged cell gravity should be at or near 1.275. 1.260 is OK Variability between cells should be no more than .025 + or -. Jim
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
