Re: How tight should the rod bearings fit?
Posted by glennster on January 06, 2011 at 11:33:14 from (76.223.251.130):
In Reply to: How tight should the rod bearings fit? posted by Sam Eubanks on January 06, 2011 at 10:32:16:
if you have the clearance specs for the bearings, zip on over to napa and get some plasti-gauge. its a thin wax like string that compresses when the bearing is torqued. there is a chart on the package that will give you the clearance when the bearing is torqued to spec. most insert type bearings do have a little "wiggle" to them.
