Properly fitted connecting rods/bearings will ALWAYS slide from side-to-side within the limits of the journal width. There HAS to be enough play (typically in the .0175" to .0035" range) for the bearing to "float" on a film of oil. Much tighter and the bearing will lack lube, overheat, and seize.
If I were to worry about anything overtightening the bolts would have done I'd worry about stretching the bolts and weakening them.
Typically, if the bolts are replaced the "big end" of the rod should be checked by a machine shop with a rod machine.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
