Re: Farmall A. Help, I've got an oil leak!
Posted by Enar on January 06, 2011 at 17:25:48 from (98.244.241.123):
In Reply to: Re: Farmall A. Help, I've got an oil leak! posted by leroy in ne on January 06, 2011 at 17:03:25:
It could be. But I think there is too much oil for that. I checked around the fan, because that was leaking, but it wasn't leaking much, so I didn't "fix" it. After all, I am just as old as that tractor and I leak a little too!
