Re: Farmall A. Help, I've got an oil leak!
Posted by andymd on January 06, 2011 at 18:05:44 from (38.114.89.2):
In Reply to: Farmall A. Help, I've got an oil leak! posted by Enar on January 06, 2011 at 15:52:20:
you said you replaced the pan gasket,what about the front seal.it will leak there look behind the front pulley i bet you will find it wet
