It is leaking at the front main seal. They are known for leaking around both the front and rear main seals. In removing the oil pan, the aluminum lower part of the front main seal must have been tweaked just a little bit which started the oil leak. I don't know if there is a way to fix the leak without pulling the motor or not because I did the seals on mine while my motor was on the engine stand.
