Re: 706 hydraulic oil
Posted by bc on January 06, 2011 at 18:40:34 from (71.158.220.25):
In Reply to: 706 hydraulic oil posted by Lee Wilson on January 06, 2011 at 14:46:39:
You may want to check the rock shaft housing under the seat. There is a plate with a number of bolts. Be careful with the gasket. It will hold a gallon or two and you may find a layer of sludge in the bottom. It is where the return flows into. There is a tall drain pipe plug that holds the fluid level up towards the top.
