Re: B-250 Glow Plugs
Posted by Redfan on July 08, 2000 at 04:14:55 from (203.87.53.9):
In Reply to: B-250 Glow Plugs posted by Dunno on July 07, 2000 at 11:36:35:
Another option is to make one of your own. Find a piece of wire the same size or fractionally bigger and bend to fit. Did that often on our Aust. built tractors that used the same glowplug setup. Regards, Redfan.
Post A Followup
: Re: Re: B-250 Glow Plugs
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
