When I did this A back in 1975 I unbolted the steering and rolled the front wheels out from under the tractor. You have to support the engine. The hood and radiator was already off when I bought it. Then you can access the damper pulley and pull it. You need to look at the hub on the pulley since it will probably have a groove worn into the surface of the hub from the old seal. You can install a speedi-sleeve over that groove so the new seal has a new surface to ride on. I had to pull the engine on my tractor since it needed a complete rebuild with new sleeves, pistons and bearings. Hal
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
