Re: Brakes !!!! Won't Shift???
Posted by Owen Aaland on January 06, 2011 at 22:22:34 from (65.161.86.69):
In Reply to: Brakes !!!! Won't Shift??? posted by Farmall Dann on January 06, 2011 at 21:54:18:
Not rolling while in neutral sounds like the brake could be dragging. The incorrect adjustment of the clutch and TA linkage added to dragging brakes could cause the symptoms your are describing.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
