Re: Brakes !!!! Won't Shift???
Posted by mkirsch on January 07, 2011 at 05:21:11 from (64.80.108.56):
In Reply to: Brakes !!!! Won't Shift??? posted by Farmall Dann on January 06, 2011 at 21:54:18:
Your TA clutch isn't releasing when you press the clutch pedal.
In order to shift, BOTH clutches have to disengage, the main and the TA.
If the TA clutch doesn't release, the TA unit binds up and the tractor won't roll in one direction. It is also very hard to shift.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
