Re: How tight should the rod bearings fit?
Posted by Heat Houser on January 07, 2011 at 06:24:58 from (69.66.35.73):
In Reply to: How tight should the rod bearings fit? posted by Sam Eubanks on January 06, 2011 at 10:32:16:
You did not squash the bearing inserts at all since the cap "bottoms" on the rod shoulders (where the bolt holes are). What you have done is to over torque the bolts which may have taken them beyond their yield point. You may want to consider replacing the bolts with new.
Note, your movement from side to side indicates that you did not and could not squash the bearings......the cap/rod shoulders prevented this.
