Posted by IH fan on January 07, 2011 at 09:37:19 from (70.254.28.180):
In Reply to: 340 Hydraulics posted by Faster346 on January 07, 2011 at 08:24:12:
I can tell you from experience of working at a hydraulics factory for 38 years, that it takes very, very little water to make the fluid milky looking. Probably to the point that there isn't enough left if you changed it 3 times, to hurt anything in warmer weather. Are you certain you are not continuing to get more water in the system?
We had the same problem when we got a heat exchanger leak in a test stand... you got out what you could, then tried to leave the lid off the reservoir and "cook it out" over time... sometimes it took a while. If there is a way to leave your reservoir open, you might try putting a heat lamp under it over night or whn not in use, circulate it a little every day and keep it heated for a few days. In the test stands where we had heaters that would heat it to over 212 degrees, it didn't take as long.[/list]
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
