Re: live hydraulics for 1945 M
Posted by Armand Tatro on January 07, 2011 at 16:37:01 from (71.239.9.235):
In Reply to: Re: live hydraulics for 1945 M posted by sflem849 on January 07, 2011 at 09:09:08:
The only problem is the belt pulley on the crankshaft is to narrow because the Char Lynn P. S. used that narrow belt. WE did find a heavy duty belt that that care of that broblem but a wider would be nice. When we are using the loader and attatchments we are not using the 3 pt. and attatchments and vice versa altho the valves are hooked in series. With the loader my son and I uloaded a floor mounted verticle milling machine from a trailor and carried it into the shop that weighed maby 1500 lbs. With fork lift mounted on the 3 pt. and a bucket full aof dirt for a counter-weight we picked a pallet of metal roofing that weighed 1000 lbs or more and lifted the bundle maby 10 or 12ft. to the eve of a building. That pump will definatly lift more than the belly pump and it does have its own tand that haold about 10 gal. hyd. oil. If you have any more questions please ask. Armand
