886 TA
Posted by nc460 on January 07, 2011 at 17:49:04 from (75.200.152.138):
I replaced the pump that is attached to the multiple control valve (MCV), because the clutch, brakes, and steering would only barely work at an idle, and decided to rebuild the valve while it was out of the tractor. Before working on it the T/A was working fine, it would go from low to high and back. Now after the rebuild and new pump the brakes, clutch and steering are working great, but the T/A wont shift from low to high, it is stuck on the low side. The lever works normally and isnt stuck. Anyone have any suggestions
