Re: Charging system on H that has a magneto.
Posted by John T on January 07, 2011 at 18:39:35 from (66.87.11.23):
In Reply to: Re: Charging system on H that has a magneto. posted by Fullers Farmalls on January 07, 2011 at 14:11:14:
There should indeed be near battery voltAGE ON THE BAT and LOAD terminals on the VR but once running at RPM there obviously must be more then 1 volt on the Gennys ARM post or GEN/ARM on the VR as those are wired together. If you only have 1 volt on the gennys ARM post when running shes NOT charging.
Jim was kind enough to post above a link to my Troubleshooting procedure so run through that n see what you find. In its Para 5 it tells how to determine if non charging is a Genny versus the VR problem and for sure be sure the genny is polarized as Bob pointed out
John T
