Small pits on the balls the size of salt grains with good flat smooth areas that are more than 80% of the total area (don't measure it) would be fine. Pits that have made the balls out of round are not acceptable. Ball roundness measured with a micrometer or caliper should be within .005" (opinion) Grooves in the ramp that you can feel by dragging your finger up the ramp are in need of smoothing. If they are so deep that machining is needed, different plates might be the answer. Jim
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
