Re: Surging 400
Posted by old on January 08, 2011 at 11:10:57 from (4.245.13.139):
In Reply to: Surging 400 posted by redgems on January 08, 2011 at 10:34:43:
When you did the carb and gov. did you follow the book as to sick the carb to the gov?? If you say no then start there if you did then you need to open up the main jet till you have it working as it should. That is caused by either gov. problems which in this case could be out of sink with the carb or running the carb lean
