Re: Found out its the Genny....
Posted by John T on January 08, 2011 at 12:15:48 from (66.87.0.12):
In Reply to: Found out its the Genny.... posted by Fuller's Farmalls on January 08, 2011 at 09:37:51:
The most common genny problemns are worn down brushes which are easy to repair yourself. Also make sure the brush hold down springys are free and are putting downward pressure on the brushes and the commutator is shined up clean free of oil and carbon. The bushings/bearigns cant be worn to where the armature is brushing the field poles.
My Troubleshooting procedure taught you how to see if non charging is a genny or VR/Relay problem and its Motor test can also show the gennys condition.
John T
