Re: Surging 400
Posted by Bob M on January 08, 2011 at 13:17:32 from (67.240.171.41):
In Reply to: Surging 400 posted by redgems on January 08, 2011 at 10:34:43:
Tony - Like old suggests problem could be improperly synch'd gov to carb throttle shaft linkage, a bind in the throttle shaft linkage or a lean high speed carb mixture.
Try this: Run the engine up so it's surging. Now VERY SLOWLY pull out the choke knob. If you find a choke setting where the engine settles down and runs smooth, problem's a lean carb setting. However if it continues surge, or begins bogging down the exhaust smokes black, the problem is with the governor linkage.
