Posted by El Toro on January 08, 2011 at 13:48:37 from (108.3.200.96):
In Reply to: Timing a Cub posted by Dave H (MI) on January 08, 2011 at 13:02:54:
You need to be on the compression stroke when you install the distributor or mag. Remove No1 plug near the radiator and hold your thumb over the plug hole while a helper slowly cranks the engine until you feel pressure against your thumb. Have the helper slowly keep cranking until that piston is a TDC on the compression stroke. Then remove the cap and see where your rotor is pointing. If you have enough clearance between the cylinder head and hood you can drop a plastic straw on top of the piston and watch that straw rise and when it quits rising your piston should be at TDC. Hal
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
