Which pump do you have? The number on mine is 355 515 r95 which according to the parts manual is an option off of the 363 779 r94. According to the manual the gasket kit I would need is 363 783 r94, but I can't find that thing anywhere online. Do remember if you got a gasket kit with the original part number or if they were just able to substitute in some other kit????
Also, in the parts manual it's showing a spring for the bearing cover in the diagram, but my pump didn't have one when I took it apart (or else it was in such bad shape it basically disinigrated). Did your pump have a spring as the picture shows?
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
