Re: 1066 steering
Posted by LarryT on January 08, 2011 at 22:13:09 from (68.35.57.27):
In Reply to: 1066 steering posted by BradinPA on January 08, 2011 at 19:21:58:
Have you noticed any fluid migration? I have a 1206 and I am wondering if your power steering relief valve is stuck open? Does everything else on the mcv pump working? I think I would check pressure from the mcv pump. I just spoke to a friend and he had an O ring break and it was both dumping pressure and draining the steering system overnight. It was worse when it was cold due to the oil becoming heavier and more viscus and the pump wouldn't push the air out because it's dumping it back in the pan. Ok, just some food for thought. LarryT
