Posted by Owen Aaland on January 09, 2011 at 00:29:21 from (65.161.86.69):
In Reply to: stuck 460D posted by tntleake on January 08, 2011 at 12:45:27:
The rear main bearing can be change with the engine installed but it is easier if the engine is out. The rear main cap also hold the rear main seal. You also need to get the cap sealed between the seal and the rubber plugs.
If you are going to plasti-gauge the mains with the engine installed you will need to put upward pressure on the crankshaft. If you do not hold the crank tight against the upper insert you get a false reading that shows less than the actual clearance.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
