Re: Will I need to change? Using an 8 volt batt on 6 volt...
Posted by John T on January 09, 2011 at 04:41:42 from (66.87.8.178):
In Reply to: Will I need to change? Using an 8 volt batt on 6 volt system posted by BigredEd on January 08, 2011 at 18:27:10:
The answer is IT DEPENDS... If you have a Cutout Relay system it should work as is,,,,,,,,,If you have a Voltage Regulator with only a Current regulation relay it ought to work okay,,,,,,,,,However if you have a VR that has a Voltage control relay (or combo voltaGE AND CURRENT) it should really be tweaked up a bit for better charging.
The lights will burn brightly but could burn out a bit sooner due to increased current. If its a battery powered coil distributor ignition the spark will be good n hot although the points will burn out a bit sooner. Ideally one should add ballast resistance but I dont think anyone ever foolswith that. If its a Mag no difference no problems,
Cranking can be imporved if you use good quality 00 Gauge battery n starter n ground cables
John T
