Re: Switching Farmall M from 6 volt to 12 volt
Posted by old on January 09, 2011 at 10:00:14 from (4.245.8.20):
In Reply to: Switching Farmall M from 6 volt to 12 volt posted by Mark Poss on January 09, 2011 at 08:38:53:
The archives are full of stuff about doing it since it is common as sun light or so it seems. Not hard to do if you ave a few skills. A simple alternator from a 1980 Chev no power any thing a shorter belt and a new bracket and then the simple wiring and your done. That is a 3 wire alternator. One big post which goes to the battery in some way starter switch etc. then it has a plug which is marked #1 and #2. The #2 goes to the big post and the #1 goes to the ignition switch the side that is hot when turned on. You do need a diode like the radio shack 276-1661 in line to stop feed back of the ignition system
