Re: Will I need to change? Using an 8 volt batt on 6 volt...
Posted by karl f on January 09, 2011 at 10:09:19 from (172.129.46.209):
In Reply to: Will I need to change? Using an 8 volt batt on 6 volt system posted by BigredEd on January 08, 2011 at 18:27:10:
My opinion is that if you can crank it by hand, 6 volts is all you need. Correct the problems that are causing the 6 volt issues first, then re-evaluate. no sense buying a battery if the problems will still be there--an 8 volt will help mask some of those issues, but will not solve any charging problems. Should test your current battery, maybe you will need to replace it anyway.
In the mean time,
large cables, clean-brite-tite connections & redundant grounds...
-karl f
