I dont think anyone can say for certain WITHOUT HAVING THE SPECIFICATIONS FOR THE CHARGER/TENDER I sure cant sittin here in the dark
BUTTTTTTTTT that being said, some of low amp tenders only supply a trickle charge to begin with at the correct voltage so if its designed for a 6 volt battery but you use it on an 8 volt battery IM NOT SURE IT WILL SUPPLY ENOUGH IF ANY CURRENT TO MAINTAIN AN 8 VOLT BATTERY
If you hook it up and can measure positive charging current flow out of it into the battery and the battery voltage rises a bit THEN ID SAY YES ITs WORKING, but I wouldnt be willing to bet on that absent other specifc info/data...
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
