Re: Maybe its not the Generator.
Posted by Fullers Farmalls on January 09, 2011 at 15:48:01 from (72.95.172.246):
In Reply to: Re: Maybe its not the Generator. posted by John T on January 09, 2011 at 15:24:33:
Thanks John, and I stand corrected it is the resistor on the light switch. Like I've said I have the 3 position switch(it has the off,dim,bright) But i have the four terminal cutout. I have checked the wiring and it looks all good. I have the right and i did the test and it is my generator. I cleaned the brushes and everything in the generator but still no luck. It polarized right also according to your procedure and still no luck. So I'm going to take it to a local electric shop and have them look at it. Thanks again.
Keith
