Re: Front Blade for a Super C
Posted by C. Amick on January 09, 2011 at 17:55:49 from (74.107.167.131):
In Reply to: Re: Front Blade for a Super C posted by Brian Schmidt on January 09, 2011 at 17:45:19:
I have a homemade 3-point hitch, so I could add a blade back there as well. It would also add weight. I have one set of weights on the rear and I think I have a set of chains somewhere. The C-172 blade can also be mounted under the belly of the tractor for grading, right? My wife and I are in the process of buying some property and building a house. The driveway is going to be about 1,000ft. long!
