Re: Farmall A carberator
Posted by Tom Fleming on January 10, 2011 at 03:25:03 from (67.20.243.240):
In Reply to: Farmall A carberator posted by Andrew Anderson on January 10, 2011 at 02:30:25:
for one thing, your float appears to be either 1.) stuck open 2.) way out of adjustment 3.) leak in float.
also, sounds like your carb has junk in the fuel ports..........
Hard to tell without seeing it, but based upon your description those would be my starting points.
