Re: Super A not running well
Posted by gene bender on January 10, 2011 at 04:06:38 from (67.55.227.196):
In Reply to: Super A not running well posted by testanley on January 09, 2011 at 19:12:47:
You need to start on the fix by taking a compression check then check the tappet for correct settings.Now some new spark plugs mite be in order along with good wires with copper centers. Check for leaks around the gaskets clogged aircleaner. Check the dist shaft for worn bushings one by one you will find the problem these are a few of what mite be wrong.
