Re: H rear axle gasket replacement
Posted by Farmer Bob on July 08, 2000 at 21:45:30 from (208.49.9.120):
In Reply to: H rear axle gasket replacement posted by Jeff on July 08, 2000 at 19:36:38:
Jeff, Just did one on my M and it's quite a job if you want to really clean up the housing gasket faces before installing the new gasket. First, remove the wheel. If you have fluid filled rears be careful. They are heavy. Next, remove the hub from the axle. Now, drain the rear end and pull the pto housing out of the rear end. This gives you an access hole to get in there to loosen the bolt (capscrew) and large heavy washer that hold the bull gear onto the axle shaft. I would NOT totally remove the bolt because the bullgear is heavy and hard to get back onto the axle shaft without taking off the deck cover. Next, loosen the axle carrier bolts. It helps to have some longer bolts ready to screw into the top and bottom holes after removing the original ones. Carefully pry the axle carrier away from the rear end housing. Right in the center there is a boss that fits into the rearend housing. Donot pry the carrier out so far that the boss comes out of the rear end. It would also help if you have blocks or a tall jack stand arranged to support the outer end of the axle as you are wiggling it around. By having the bull gear loosened you should be able to pry the carrier away far enough to clean the old gasket material off. Once cleaned, slip the new gasket over the outer end of the axle and axle carrier work it around the inner face of the axle carrier. You will have to carefully remove the longer safety bolts you put in but one at a time to get the gasket into place then put the bolt back into the hole. Once the gasket is in place gently push the axle carrier back into the rearend housing until it is close enough that you can start replacing the regular bolts around the housing. Tighten them all snug then take out the long safety bolts and put the original bolts in those holes. Then go around again and tighten them all @ 110 ft. lbs. Now screw the big capscrew back into the axle inner end to pull the bullgear back onto the axle. Tighten as tight as you can get it in that limited work area you are dealing with. Replace the PTO gasket as well and reinstall the PTO housing. May as well refill the rearend lube with new as long as you have done all this. Good luck.//FB
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
