Posted by pete 23 on January 10, 2011 at 08:30:32 from (173.87.15.134):
In Reply to: Farmall 400 Hydraulics posted by Ohiohillbilly on January 10, 2011 at 05:18:10:
As far as the hydraulic, I would clean up the regulator valve assembly replacing o-ring and gasket, and check out the orfice screen. It may well be the original size orfice marked .024 and will surely have a least a collapsed screen. I would then cut end off screen, check to make sure it has no holes where it collapsed, and drill it out to .031 as new ones are. Could buy new one but you won't believe what they want for it at CASEIH. Roll the end of screen back up to form a nice end . For the hydraulic valve leaking down, you are dealing with a worn spool and bore in valve body as the o-rings only seal external leaking and have nothing to do with the sealing of fluid internally. In other words, select fitted so they can move free and least amout of leakage when new. You may well be able to find a used one in better shape but it will be hit and miss. You can install a check valve to hold the load like one used on the fast hitch and that will hold your load indefinetely.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
